hobbo
Hi don't know if this has been done before. When you use your headlight flasher when the lights are off, does it also change from dip beam to main, or the other way round depending which it was originally on. If the lights are on and dip beam is selected and you flash someone, will this also change to main beam. The tell tale on the dash is so dim I cannot sometimes tell what beam I am on unless outside is pitch black. Any help greatly appreciated Thanks.
