Complete Turnkey Engine £3250
Right the time has come to sell my Trusty 1776cc Engine, I had the engine built with NO expense spared, Parts alone came to OVER 6k. Oil has been changed every 1000 miles and most of the time less. The engine Bar is for a Late Bay, and will slot straight in, will easily go into ANY vw just need to get a correct engine bar.
The reason for sale is that i'm currently collecting parts for a stroker motor. After alot of thought and deliberation, i've decided to try not to split up my engine for parts as it is such a good reliable proven unit, its a strong pulling bit of kit.
Not Only has this engine bought me a lot of fun, it has for the odd few months here and there been my daily too, will sit at 60 - 70mph at a reasonable temperature on a 1600 box, never misses a beat Thanks to the electronic ignition the timing has NEVER gone out. Carbs are very good at staying in tune, only tuned and tweaked due to my over zealousness for maintainence.
Built by Mark and Matt @ AUTOTECHNIKS
In my opinion one of the best engine builders in the UK
They currently have the quickest (on the 1/4 mile) natrually apsirated Type 1 engined Bay in Europe
and also
The quickest (on the 1/4 mile) split in the Uk FULL STOP
http://www.ultimatestreetbays.co.uk/
http://www.ssvc.org.uk/bwa/
Right Important Stuff
SPEC LIST:
(all parts BRAND new when the engine was built, NO expense spared)
1776cc Engine
Dellorto DRLA36's
Matchported Manifolds
Hex Bar Linkage
CB Performance 044 Heads
40mm Inlet, 35.5mm Exhaust Stainless Steel Valves
Dual Valve Springs
Cromoloy Retainers
Bolt up Rocker shafts
Swivel Feet
90.5 Mahle Barrels and Pistons
ENGLE 140 Cam
Lightweight Followers
Double Thrust Cam Bearings
Scat 69mm Counterweighted Crank
Lightened and Balanced Flywheel
Kennedy Clutch
Solid Centre Plate
Berg 26mm Oil Pump and Cover
External Oil Filter (always used Fram HP1's)
Bosch 009 Dizzy
Bosch Blue Coil
Electronic Ignition
9.2 to 1 Comp.
Fully Stainless Steel Exhaust System
From Heads through to Turbo Muffler
and much more (if i've missed anything or you have a queery pls feel free to get in touch)
While owning and running this engine in, I've only had one small set back and that was the summer of last year i snapped a swivel foot, (my fault completely) I Got the entire set replaced and the engine overhauled before it went back into my van
This Engine genrally astonishes People, It was built and serviced by one of the best engine builders in the uk and is proving itself so. I've never found a N/A 1776cc engine in a bus that could come close to this package
As i say The parts to build this cost me about 6k let alone labour, so i'll take sensible offers around £3250
I'm in no hurry (i.e. no piss takers need apply) to sell this as its currently powering me about as my Daily
Will Consider Trade \ swap \ p/x \ especially on a GOOD Reliable 1600tp engine or a daily of some description?
Ill split this if i have too, Someone would get a much better deal by just buying it complete.
If i had to it would split down ROUGHLY like this:
Longblock £2200
Carbs c/w manifolds and linkage £350
FULL exhaust system (Turbo muffler and stinger included) £450
Alternator and stand £120
Tinwear, fan, oilcooler and bits an bobs £120
Coil and leads £60
Email Me : [email protected]
Ring ME : 07773 374 575
Remember the carbs on this engine are only DRLA36's (a good happy medium at the time for me) if these where swapp'd for 44's, Fun Factor would seriously INCREASE
sorry bout crap pic of the engine but only ones i have at the mo.
in situ:
Built by the Men that bought you:
and also
SPEC LIST:
1776cc Engine
Dellorto DRLA36's
Hex Bar Linkage
Dual Valve Springs
Cromoloy Retainers
Swivel Feet
ENGLE 140 Cam
Kennedy Clutch
Solid Centre Plate
Bosch 009 Dizzy
Bosch Blue Coil
Electronic Ignition
9.2 to 1 Comp.
Longblock £2200
Coil and leads £60
in situ:
