Dirty Harry
Ok, here we go.
Starting with the front window curtain, this one is curved at the top of the windscreen in the middle it measures 560mm at both outher ends it's 490mm and it's 1290mm long
The seam at the bottom and sides is 15mm (3 layers) at the top where the snappers are the seam is 45mm (3 layers)
Cab doors.
600mm high and 1000mm wide, all sides have a seam 15mm (3 layers) at the top there is a silent gliss tape.
Sliding door.
520mm high and 1370mm wide all sides have a seam of 15mm (3 layers) and at the top there is a silent gliss tape
Back and jalousie window
4 pieces of 520mm high and 670mm wide bottom and both side have a seam of 15mm (3 layers) at the top there is a sleeve of 50mm
Rear hatch
390mm high and 670mm wide, the sides have a seam (3 layers) of 15mm the top and bottom sleeve is 50mm
I could not measure the curtain behind the wardrobe but i think this is about the same size as the one from the sliding door.
If you need more just let me know!
Cab doors.
Sliding door.
Rear hatch
