pottinger
hey all,
got some led strip lights (single colour) 5 metres 24w 3a
now, the connection off the led strip is a pos and neg wire.
the wire itself is VERY thin.
i was going to run a wire from a fusebox (fused at 3a) onto a switch then onto the LED strip.
If i run a normal size wire (ie a 5amp wire) from the fusebox to switch then 5 amp wire from the switch to the ledstrip, surely the wiring that is on the LED strip is a weak spot ???
ie, the 3amp fuse prortects the 5amp wire, but what protects the wire you attach to on the LED strip ? :msn4: :?
doin my head in this is :lol:
a thought id finished but obviously not potts.... :roll:
