Headlights stuck on main beam...
Bears Dad
May 28, 2009
302
2
Buckinghamshire
Afternoon...
So just switching over my bulbs to something brighter and I’ve noticed my headlights are either full beam or... full beam. Even with the original bulbs back in.
I’m guessing the culprit is either relay or switch...?
Any easy ways to check?
It’ll only be (potentially) cooked if you uprated the wattage on your bulbs to higher than standard. Which from your other post I don’t think is the case.
Had the same happen to me buddy - remove the flasher relay (guess its stopped clicking when you pull the stalk back)
If its an OG one it'll be able to open and clean up inside then reinstall and all should be good.
It could be clicking but not latching - ie disconnecting the power from the main beam, Id still pull it from the fuse board and give it a look over and clean. Cant really be anything else. Mine was a rather large relay that was full of junk when I removed it - sprayed contact cleaner in there and its been good as gold ever since
Where is the relay hiding???
Mine is doing the same thing!
Is it just under the dash?
I’ve not looked yet like!
Had the relay out cleaned and WD40 all connectors - still not playing the game.
Where’s best to get replacement relay from?
