doz
- Joined
- Jun 9, 2011
- Messages
- 398
- Reaction score
- 0
Right bare with me this is gonna be a bit long winded. I apologise in advance maybe worth getting a brew and if need the loo best go now :shock:
I rebuilt my 1600tp motor about 2.5 k miles ago, spec is
1835cc
Engle 110 cam
1.25:1 ratio rockers
Balanced std crank, rods and flywheel
HP Oil pump with external cooler
Chome moly push rods
Vintage speed exhaust
Twin Kadrons jetted and kaddie shack ventures
Old school ported, polished ex drag car cylinder heads with 30cc combustion chambers
Everything was great. Cam burn done, and run in. Unfortunately recently I had a spark plug break up and knack the barrel and when I stripped the motor down the heads had cracked. So I set about doing a top end build. New p&b's with cb performance heads. As the heads were some what taller due to my old heads being heavily fly cut I replaced the pushrods again cutting them to correct length and making sure the rockers were shimmed correctly.
So engine rebuilt and running in again, I've covered about 400 miles. Problem is I've had to set the tappets 4 times since the rebuild. Everytime the gap gets to big. Ive tried 0.004" gaps and 0.006" gap and both end up with same issue. When the barrels were off I checked the cam followers and cam for wear but they looked in excellent condition.
It didn't act this way when I first built the engine but then the heads were second hand but reconditioned. Could this constant gap issue just be down to everything bedding in? I would of thought the gaps were more likely to close up ith new valve seats etc not keep getting bigger.
I've set the tappets the same way I've always done them. Dizzy cap off, rotate engine until dizzy arm is pointing to the ht lead I want to check then set the gaps on that particular cylinder. Rotate dizzy through one complete turn then recheck the gaps. Am I doing something wrong maybe?
1835cc
Engle 110 cam
