Just fitted a new replacement indicator unit on my US 70 bus, but I've now got a problem where the buzzer sounds (not continuous, but like on/off twice a second) and the right indicator bulb on the front passenger side does not light up.
So, this is what I've tried/noticed...
- Hazard switch works as normal. All indicators light up, although they do flash a little on the fast side.
- I've checked the fuses for continuity, they are fine.
- Swapped the bulbs around, they all fine.
- Also checked the relays, disconnected/rec-connected. As the hazard works, this should mean the relay is fine.
I'm now going over the bentley manual and checking any wiring relating to the indicator/buzzer.
Any other ideas?
Any other ideas?
