Sorry Trikky2 ,Lets get the facts right. First of all let me say that I have been involved with VW 'air-cooled ' engines for over 50 years. I stand by the fact that I have stated they are cooled by oil.Lets first look at the cooling of cylinder heads.The heads are cooled as stated by air flow from fan housing after it has cooled the oil cooler.Why do so many people have problems with cracked heads ? The main problem here is badly adjusted carb running too lean and ignition timing not set correctly.Some people fit 009 distributors, these were never fitted to road going VW engines but were fitted to static industrial engines,ie water pumps,generators etc where engine was running at constant speed.You mentioned the flaps in the fan housing which are controlled by thermostat.The purpose of these flaps is to get the engine warmed to running temperature quickly.If that thermostat fails to open you are going to a massive heat problems. You mentioned user in Australia and North Africa, well I think you will find a lot of these guys remove these flaps so no restriction to cooling. Also I think you will find that these guys don't try to use them in general as race cars.In the 70/80's a lot of guys from Australia would travel overland to UK and then sell them to get air fare home. What you have to remember that the engine in type 2 is from a beetle and has shove nearly 2 tonne around. Over the years VW has increased the size of oil galleries and fitted a dog house oil cooler where the heat from cooler is expelled out of fan housing as well as designing twin port heads which disperse heat more.In general the oil capacity of our engines is about 2 1/2 Ltr's, not a lot unless you have an add on sump fitted.The purpose of the oil as well as cooling is to lubricate all the moving parts of engine. If that oil gets too hot it looses its viscosity and is not able to form a film between bearings and journals and we know what happens then.Fitting an extra oil cooler as K@rlos has done goes a long way to solving this problem.He says that he runs at 70/80mph with out any heating problems. I wonder how hot his engine would get with out his extra cooler.
Robert
