Big Nick
Just had my van set up and rolling roaded, its putting out 76bhp at the rear wheels which is I guess around 100 at the fly wheel about right for my engine spec. However not long after this was done (and after a bit of a thrashing) I have noticed a intermitant stuttering between around 2200 (normally 2500) and 3000 rpm when the engine is under load, it does not happen all the time and seems to be absent at lower and higher rpm, The symptoms are if it is momentarily starved of fuel or spark (we are talking fractions of a second here).
Brief engine spec, 1776, engle 110, Empi style 044's, 009 with ignitor ignition and coil, dual 40 Empi webber rip offs (showing some signs of wear), facet electric fuel pump with regulator valve. Engine cooling is well sorted (Internal and external coolers - with by pass and deep sump) and typical running temps are between 70 and 95 degrees when running at 50 to 60 mph.
Today this only occured after the oil was up to 70 degrees plus (normally when the engine is at its happiest).
Any thoughts (I have checked all the leads and they seem to be located fine).
Thanks in advance
Nick & Zile
Thanks in advance
Nick & Zile
