As listed in the title:
First up, a Weber 32/36 Progressive carb, complete with manifold, filter, and (I think) support bracket (small brass bit pictured below).
This is a genuine Weber carb, stating it is made in SPAIN, and I reckon it would clean up very nicely, there is no real tarnishing/oxidation to the carb body. Came off a running 1600 a while ago, and it's just been sat since. Preheat pipes are clear.
As with any secondhand carb, I'd give it a clean and a rebuild kit before fitting it to an engine, but it ought to be OK as is. Rebuild kits are £15 on eBay.
Bad bits:
Air filter chrome top has a few small pits in the chrome and is missing clips to hold it together, these are available seperately cheaply, or a brand new complete filter is £25 on eBay.
Manifold pre-heat pipes seem slightly loose, but I'm sure some chemical metal or similar would sort that if it is a problem.
£120.
VW 1600TP manifold ends, nice clean pair, £25. Used with the above manifold, but suitable for a stock 1600TP too.
Pair of finned alloy bolt-on rocker covers. Missing one fixing bolt (standard M8), but the special long hex-nuts to attach it to the rockers are all present. £20 the pair.
Collect from Bristol, or post at cost
Bad bits:
£120.
