Porsche brakes, parts, engine and Panels
slowmo
Jun 17, 2008
283
7
All parts can be shipped at cost or possible delivery to busfest on the larger stuff
Early bay rear hatch £170
Early bay rear corner repair £10
Repair section of cargo floor £90
OS front dogleg not inc step, cut from an import £100
OS wheel tub cut from a import van £30
Couple of cuts of the rear parcel panel above the engine £30-40
Rear valance triangles (rear valance bolts to) £30
Windscreen pillar cuts £10 per side
Ambulance fans and headlight switch £160
Early bay air filter housing £40
Rear hinge covers £10 a pair
T25 engine hatch £30
Heat exchangers REPRO £80 pair
4x 1600 pistons and 6x cylinders £20
1600 twinport longblock with bus mounts (siezed in one of the cylinders) £400
1776cc motor inc 40mm DRLAS £2900
PORSCHE
Early 944 front calipers, disks and hubs, disks worn with large lip £280
VW split or bay bus Porsche disk brake conversion Kit consists of caliper adapter brackets, hub spacers and brand new ATE disks £200
Porsche Boxster caliper brake kit to suit bay or split.
Pair of bearing spacers, caliper mounting bracket (powder coated) and fasteners to fit early Porsche Boxster calipers to 944 hubs with 911 disks. £140
Also have pair of 924S rear aluminium trailing arms with handbrake mechanism, used disks £250
Early rear 944 trailing arm with rear discs, calipers etc £420
Set of 4 cookie cutter Porsche allots 15x7 £200
Early steel 944 trailing arms £60 pair
Brake master cylinder 944 aluminium and reservoir £40
Rear drive shafts 944 £80
23.5mm torsion bars 944 £40
944 rear spring plates £60
5x130 steel spare wheel £120
Ah no worries, gotta sort those ambulance fans out with you. Dubfreeze is a little far at the mo what’s the next show your planning down south?
Not sure atm, I can post for £4 if that’s of interest.
