Doris
Hi all,
Ideally looking for a definitive answer on this topic if poss. I've found many threads on it but never a solution.
So, where did you get the 12mm ID pipe that runs from the upper filler/reservoir to the lower one on top of the master cylinder?
Its a 69 so it has the filler above the kick panel & pedals and originally had a hard plastic pipe which is now cracked and brittle.
I've tried FLAPS,the usual suppliers and went into Pirtek yesterday, I thought if anyone could help,they could - but no. They rung around with no joy. I keep getting offered fuel hose which is not brake fluid compatible. :-/ Looking at it, even if I found another 2nd hand plastic pipe, I've feel more comfortable with a nice fitting compatible hose.
I can't be the only person to have to have replaced it, so anyone got any leads/links or advice or Doris will be going nowhere! :-(
Thanks - Rob
In short looking for brake fluid compatible hose of 11 / 11.5 / 12 mm Internal Diameter
Thanks - Rob
