Is there anywhere that lists the original colour wires and what they do/where they go?
I am tidying under the dash and have located a few unattached wires, I have removed the ones that I can trace, but there are some I cannot trace. One in particular is blue/red and disappears behind the fuse box, posibly up the door column, but there is no more than 12" hanging by the fuse box with a male spade connector on the end...
I also have a brown wire from pin 31 on the emergency flasher relay to the dash switches, but this has a male connector half way along, I read the Haynes manual and translated this as an earth point so attached it to one of the tabs by the block connector below the upper left corner of the dash, can anyone say if this is correct?
