aogrady
As i am going off grid, i have this for sale. I fitted a new blue neon main on off switch as the original was stiff and didnt work. I have only hooked it up once to the mains as a test to see if i had 12v output, and then as usual never wired it in properly as we haven't been away. Some of the glass fuses need replacing, but you need to use the correct size with what ever you are running anyway.
2 below pics taken off the net.
Note the front is shiny, not patterned at it shows on the photo.
The double socket i am keeping for my inverter...
I may have a cable for the back of the zig to power a fridge, will see if i can fish it out.
Here are CF9 instructions if you want them:
http://www.freewebs.com/12voltsdc/Zig%20CF9%20Manual%20PDF.pdf" onclick="window.open(this.href);return false;
Any questions, just ask. I am in Barnstaple, North Devon, will post if you cant collect.
Cheers!
Alistair
Cheers!
Alistair
