t2awestfalia1968
- Joined
- Sep 19, 2016
- Messages
- 10
- Reaction score
- 4
- Location
- Pershore
- Year of Your Van(s)
- 1968
- Van Type
- Microbus
Check all connections and clean defo fit hot start relay anyway and see what happens?
Choke stuck?Sorry to jump onto your thread,
But I have the same issue, once she’s hot, if i turn her off I can’t start her again instantly, but if I leave her for a minute or so then she won’t start until she’s cooled down, just turns over and over and over making no attempt to start,
I thought it would be fuel evaporating but I turned her over until the battery almost died once and she didn’t fire back up (until she had cooled down 30 mins later) I’d have thought that would have been long enough for the fuel to travel through
Takes a little bit of enjoyment away from her as I can’t nip to the shop or anything,
Again sorry for jumping on your post, I can make a new thread if you’d prefer?
Jake
How could I check this? she is running very rich, turns the back bumper black near to the exhaust so this would make sense! I hadn’t thought of thisChoke stuck?
WooHoo Mike202!!Sounds like the starter motor, does it click when you turn the key. Have you tried tapping it with a hammer to see if the solenoid is stuck?
Mike, that is possibly the best write up on ‘Won’t Start’ I’ve seen put together. I’m hoping we can have that as a sticky in technical.Have a read of this article. Your starter may just need a clean up.
http://www.vw-resource.com/car_wont_start.html
Not sure if you've sorted this but the most common issue with this is that the cable travels to the ignition switch and back again so you get volt drop as a matter of course, this coupled with the heat from the engine bay meaning the resistance builds up in the cable and your starter wont get anything like the voltage needed to fire the solenoid, or the solenoid fires but the cable cant carry the current required by the starter so it turns very slowly and the engine wont fire. Mine did the same when I got it back in 2007.Hi all. so I have had an issue with my bus since I got it. Once I start a journey if I stop even early on to go fuel up at the petrol station it wont start again and needs bumping.
So if I loose revs and conk out I'm knackered ! once I get where I'm going and say the morning after it fires up straight away.
I have been changing parts trying to get to the bottom of it. It might not be the fact that its hot but I think it is.
New battery ,new starter motor (but used), new alternator , new coil and ignition leads.
still the same.
Any ideas ?
