bluenose
I just did this last weekend. Was pretty easy to be fair. Seals and trim were all from C&C and fit well.
They do sell them for without quarter lights, might have to ring them.
My method was,
put seal on glass
Positioned both delux trims on the glass so that the corners were in the right place as a start point
I pushed the trim in by folding down the outside of the seal to open the slit and pushing the trim in. it's very easy to bend and damage so be carefull.
when you push the trim in the seal lip ends up tucked inside with the trim so you need to get it out. I did this by running a pick down it just like the one on the far right in this pic. I found this tool priceless for doing this job and it only cost £3 for the set from machine mart.
I found a bit of talc helped get the windows into the van also, they were a tight fit!
My method was,
put seal on glass
