Has anyone got any idea what the diameter of the smaller ball bearing check valve is on the solex pict 34? I need to buy a replacement but am unsure of size. Thisis a very tiny ball that is located inside a long passage, again on the accelerator pump side of the carb. This passage is critical for gasoline passing from the accelerator pump to and through the injector tube–the brass tube that seats into the carb’s edge and squirts gasoline downward into the carb’s throat.
