Late cab door
Doing some research all I can see is a convertor kit to fit early bay doors to a late bay. There seems to be a number of forums saying a late bay door has a 20mm as opposed to a 10mm section where it meets the step. So maybe incompatible?
Sent from my SM-G975F using Tapatalk
I found conflicting info as well, I knew hinge pins may be different but was unaware of size difference as the door skins fit all years. Must be door depth by the step area.
This may or may not help
https://r.tapatalk.com/shareLink/topic?url=https://thelatebay.com/index.php?threads/how-to-identify-your-vw-baywindow-cab-door-and-hinge-type-thread.75586/&share_tid=75586&share_fid=5720&share_type=t&link_source=app
If you scroll up there's some comprehensive details on the different years
One of my cab doors is off a '72. It's almost identical apart from the door card mounting holes are slightly different.
Heinz said:
That link is great, I have a really late door so need the hinge conversion kit.
No probs, hopefully it will solve you issues but you need to check the step depth as still unsure???
