DRLA 36 Dual carbs, to banjo or not to banjo
Dci_Carter
Jul 20, 2015
130
Hi all,
I'm configuring the fuel pipe for my Dellorto 36 twin carbs. The Dellorto book says you can daisy chain the carbs together using a feed pipe from the left carb to the right by means of a dual banjo fitting to a single. However I have also been advised a fuel pipe t'eed to both sides with single banjos is as effective?
Any bods out there with some views ?
Sent from my SM-G975F using Tapatalk
I personally prefer a t piece. Fitted twin carb setup’s this way from 34’s to Jaycee 51.5’s and it’s always worked fine.
I've always run mine with a stock pump (and pressure regulator), with the pump linked to the left carb and then a line from the LH banjo to RH carb.
I think either way is OK. :)
Thanks guys, as I've only a single banjo on both I'll go for the T option
Mine came with a dual banjo so I used it. Since then I've fitted using a single banjo, as that's what it came with, and a t-piece - couldn't actually get the right dual banjo anywhere.
