Hi all,
Has anyone ever replaced the clip on the clutch cable where it meets the pedal?
I had one (on the left in the pic below) wear completely through on my van while we were on holiday in Spain... At the time, I bodged it with an M6 bolt and continued the journey. I assume the one that failed was original to the van - so it failed after what I believe to be at least 258000 miles of driving.
I bought another, and found the pin had a lot of freedom of movement relative to the clip. Probably able to move 10-20 degrees or more. Upon fitting it, it failed on the first time of pressing the clutch - the pin became separate from the clip.
In fairness to Just Kampers, who supplied it - they sent me another one which arrived within 24hrs of me phoning them (thanks again ). However, this one has the same amount of play in it - the pin can wiggle a good 10-20 degrees of rotation relative to the clip.
Has anyone had this problem, or used a repro (with a similar amount of play) without issue?
I'm very tempted to weld the pin to the clip, but I assume it is meant to have some freedom to rotate...
Thanks,
Jim.
Thanks,
Jim.
