Best brake master cylinders for 944 brake set up?
AD4M
Feb 26, 2012
107
Hi All,
I am part way through fitting 944 front brakes and have notced my master cylinder leaking. My van is a 69 so doesnt have a servo. What is the best master cylinder without a servo? I assume it would be best to fit a servo designed for front discs?
Any help would be greatly appreciated!
Im also after some advise about where to get a hub seal from as I need one that will fit the porsche hub and the van drum hub carrier.
Thanks again!
Ideally i'd rarther not have to rework all of the brake pipes as they are perfect.
You're going to have a bad time without the servo.
I used a 944 master and a golf 1 servo. Not very expensive and works good.
I even have a spare 944 master if you want ;)
