Brake Fluid Filler to Master Cylinder Hose - What is special about it?
cunning plan said:
I wonder if the composite of PVA and EPDM is what creates the resistance to brake fluid? The hoses I have been looking at are just EPDM, no PVA inner. :popcorn:
Well they're layers, so it's an epdm straw with two PA straws over it, with another epdm straw over all of that. The PA is just for strength- the rubber brake hoses between the master cylinder and wheels would blow up like a balloon without it I believe- certainly wouldn't want to test it. There's up to 2000PSI in the lines from your master cylinder to the wheels- hence the absence of compression fittings & hose clamps etc. They'd just blow off.
The low pressure hose from reservoir to master cylinder doesn't need it though as they're not under pressure- they just fill the master cylinder up- so straight EPDM hose is fine for that :)
Try this out?
http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjb-bG_huvTAhUKCsAKHcs6CEIQFghKMAA&url=http%3A%2F%2Fwww.carbuildersolutions.com%2Fuk%2Fbrake-fluid-filler-hose-10mm-id&usg=AFQjCNGbdEptfP1OvR9RdBWzdGktyM8seQ
J
gas1man said:
Try this out?
J
That would do it! Good find! :mrgreen:
Thanks! I will be happy to use EPDM now, although, I do have an original one on Back Order :lol: :? :D
I bought the proper clear pipe from C&C and it doesn't fit a 72 cross, its too short so i opted for epdm and jubilees a couple of years ago. No leaks no probs.
Sent from my SM-A320FL using Tapatalk
Hi,
The hoseworld website says this:
EPDM RUBBER TUBE
APPLICATION: SUITABLE FOR HOT WATER, AIR
WIDE RANGE OF CHEMICAL RESISTANCE (Please check compatibility)
SUITABLE FOR USE WITH Dot4 BRAKE FLUID
cunning plan said:
Moseley said:
Epdm is the standard rubber used for all coolant / air / low pressure brake fluid applications. The reason why it isn't overly documented in low pressure brake fluid use is probably because not many vehicles utilise a remote reservoir and therefore have no need for it. Epdm is incompatible with fuel and oil as far as I'm aware, so it is important as to where any hose off cuts are used!
Noted, thanks :)
Freezzr said:
Kieft & Klok sells it, I installed the hose yesterday and it fits easy and OK!
Thanks, I just had a look, but I can only find a '73-'79 version on there:
http://www.kieftenklok.nl/shop/index.php/en/homepage/t2-1968-1979/remmerij2013-11-06-11-11-00/overig/pipe-between-brake-fluid-reservoirs-8-73-7-79-detail
If you have found an early one, please could you post a link? :sign0009:
Sorry for my late reply but: http://www.kieftenklok.nl/shop/index.php/front-page/t2-1968-1979/t2-remmerij/remleidingen-en-slangen/remvloeistof-reservoir-slang-8-67-7-79-detail
Johnny said:
slow-lane-Matt said:
It might find itself under pressure if you use a Gunson bleed kit.....
haha true :)
I can attest to this, our rubber collar at the top was mushy and exploded in my face when trying a pressure bleed. luckily I wear glasses. I had to reengineer the connection with components I had around the place as "the rubbers were were beyond their useful life"
I got one from C&C but turned out to be the shorter one for under the seat reservoir. I used EPDM hose from Advanced Fluid Solutions as they say it's good for brake fluid that's not under pressure. They are experts and sell 100% biofuel hose too. It's been on a couple of years with no issue at all. The only thing i would add next time is some Copex convoluted conduit to protect from debris and the weather. This can be pulled back to inspect the ends.
Use correctly sized 'Oetiker' clips or small 'ABA' fuel hose type clamps as Jubilee/worm drive clips are never quite round when in small sizes and can cause a leak, damage the hose or crush the plastic spigots. Also, if you underseal then mask any hoses beforehand. Its usually spirit based and won't do the rubber any good.
cheers
dave
