Does anyone have a contact in the Swansea or South Wales area who knows how to sort the timing on an air cooled engine. Pulling my hair out can't get it right. Engine runs fine when cold but struggles on hills when warm.
thejinx said:Well!! I set valve settings today.
No 1 to tight
No2 just right
Nos 3 and 4 I could have put the entire tool into the gap
It sounds much better now and touch wood drives better. Running a 009 dizzy at the moment still have the stock one may go back to it.
As I said at moment I am running a 009. I see they are meant to be set to 32 degrees. If I understand the clip. I need to loosen dizzy. Mark 32 degrees on my stock pulley. Once done Rev engine and see if 32 degree mark is sat on my timing light and mark. If not turn dizzy anti clockwise until it is. Once there lock down dizzy. Sound right? Cheers
