Group Buy - Firetec fire extinguishers for engine bay
adamski
Apr 26, 2007
624
Fulham
Please post if you are interested in a group buy, need 3 minimum.
Discounts passed to VW clubs or associations: discounts apply only to the actual systems i.e. those costing £140 and up. Discounts are not offered on optional LED switches or Chafegard which are already sold at cost.
Re discounts: Discounts against single orders of 3 to 7 systems: 10%, 8 to 12 systems: 20%, 13 to 25 systems: 30%. > 25 systems: 40%
Which system are you thinking of and what is its cost before the discount?
Thanks to Cotswoldiver
FIRETEC CT AXIAL system for VW T1 /T2 Campers
Fire Monitoring Systems manufacture an automatic fire suppression system for use in VW campers.
These are basically especially configured Firetec CT Axial systems.
The Firetec CT equipment is described in http://www.FiretecUK.com" onclick="window.open(this.href);return false;
Specifications for use in VW T1 / T2 campers.
Cylinder: model B1. 340mm x 85mm diameter. 1.2 litres aluminium.
Tube: 3.50 metres 6.2 x 4.0 heat sensitive REACTON 80.
Valve: Stainless steel Firetec Axial valve with easy top-up external
Schrader, safety pressure gauge, and tube connections.
Bracket: Special flat-bar-bracket for auto systems, with countersunk bolt kit.
Extinguishant (default): special mix, 9% AFFF, non corrosive foam.
Installation options:
Upright on LH chassis leg, horizontally on LH chassis leg or horizontally under engine compartment ‘roof’.
Buyer must state if under-roof configuration is required.
Instructions:
Standard CT instructions with extra page specifically for VW T1/ T2 campers included.
Requires good general DIY skills, but no special tools.
PRICES:
As above: .. .. .. .. .. .. £140.00
OK so we are looking at £126 each if we get up to 7 people and £112 if we can get over 8, based on this and the hope we get 8 I will put my name down for 2 kits
Graham L x 2
Are these the same as the ones shown in this thread???
http://forum.earlybay.com/viewtopic.php?f=1&t=4785&st=0&sk=t&sd=a&hilit=firetec" onclick="window.open(this.href);return false;
Either way can you please put me down for one, really need one.
maybe worth contacting this chap on ssvc http://www.ssvc.org.uk/phpbb/viewtopic.php?f=4&t=38325&start=300........" onclick="window.open(this.href);return false;. :?
So far you potentially have......
1) Adamski
2) Graham L
3) Graham L
4) SuperDan
5) mjknight71
If we are quick, would the volksworld show be a time when we could distribute?
1) Adamski
2) Graham L
3) Graham L
4) SuperDan
5) mjknight71
6) Doris
7) Cotswoldiver
8 ) Jacksoncaddy
Anyone else :?: :?: :?:
1) Adamski
2) Graham L
3) Graham L
4) SuperDan
5) mjknight71
6) Doris
7) Cotswoldiver
8 ) Jacksoncaddy
9) Cunning Plan (ONLY iF 40% highest discount is met)
Today's update on delivery/lead times
Hi David,
delivery varies day by day. The most that we can manufacture is 20 systems per day..... and we have orders for 1800 in the pipeline. However most of these are on staggered delivery arrangements e.g. 20 / month, so it's a case of fitting in at the time. Today I would allow 10 days for despath against a single order of between 1 and 20 systems, unless all 20 are the same build, which is the quickest way for us to produce.
regards
Tim Malyon
Araon said:
With there lead times its more likely to be Big bang , Stanford Hall etc...
the problem is by the time you collect everyones money, the pass onto Tim, cheque clears, his contracts especially his MOD can come in thick and fast....your better arrangeing a workable deadline, he used to work on three week lead times maybe a bit quieter at the minute....
dry powder is the one that holds things up as he doesnt stock that much of it
so we start at £140 (minus any discount)...then add chafeguard if you want it...then add LED if you want it......then postage....plus VAT :?
What does it come too...... :?
These were the extra costs from his first e-mail
As above but with dry powder instead of AFFF foam: .. £148.00 *
As above but with gasses: all gasses available. Price depends on gas specified.
OPTIONS:
Full length stainless steel Chafegard spiral protection to tube: add £18.00
Built-in SWITCH for dash LED system status display etc:
For use with Green permanently-on LED, or red-on-when-discharged LED:
Choose switch for green or red LED. Does not include wires or LED. add £20.00
Switches can be used to complete or break other external circuits.
£140 + vat @15% = £161 unit cost discounted 10% 144.90 , 20% 128.80 , 30% 112.70 , 40% 96.60
with Chaffegaurd @ £18 = £179 , 162.90 , 146.80 , 130.70 , 114.60
with switch @ £20 = £181 , 164.90 , 148.80 , 132.70 , 116.60
with both @ £38 = £199 , 182.90 , 166.80 , 150.70 , 134.60
£15 postage to be split across the total units
remember you cant just post these out so its a matter of passing them around at shows/through clubs and meets etc....
