mattp
Collect from Leatherhead J9/M25. I am 15min from the VOWO show. If you have questions then please call 07715 623 564
If you want a picture, please PM with what you need and an Email
I WILL UPDATE AD MONDAY 19 MARCH
FRONT END MECHANICAL
NOS T2 Split K+L 64> spindles for disc brakes (K+L as on current Danbury busses, so 5*112 late bay discs/calipers) complete with spacer collars, new genuine VW king pins and thrust washers, seals –all new genuine VW parts. 650 –includes new set of repro link pins so everything from the arms out
T2 bay front bump stops (set of 4) inc. clips £10
RHD pitman arm (bay) £15
LHD pitman arm, shotblasted and primed (bay) £25
PORSCHE 944
944 Early front brakes (ATE single pots), good hubs, good discs, good calipers £200pr
944 Early front hubs, blasted and primed with studs and caps £165
944 Early manual front seats. Pinstripe, good condition £200
REAR END MECHANICAL
Late bay IRS hubs, stripped, blasted and painted. Come with new genuine seals (4) and bearings (4) bearing + 2 spacers and clips £200 (pr)
Baywindow rear suspension bump stops (pr) £4
T2 New EMPI uprated CV cages for hi performance cars £8 (pr)
Early bay IRS hub carrier NS bare £10
INTERIOR PARTS
T2 Late mint working* 12v clock with Eberspacher heater control £300
T2 Westy cot brackets (original) for cab hammock £15 (set of 4)
T1/T2 Bug/T2 etc Deluxe type winder handles, mint £20 (pr)
T25 door cards in grey £30pr
T2 Westfalia 3/4 LHD R&R bed hinges, supports, base, front and sides of underseat box £45
EXHAUST / TINWARE
VAG Tdi rear box (genuine new VAG), unfortunately too big for my T25, stainless pipes £20
NOS Heat exchangers, T25 CT which can be easily modified for use on T2/T1 engines. £250/pr
Rear Tin (over exhaust) genuine VW £8
Twin port Type1 head tines (pr) genuine VW £15
Tinware set, for type 1 engine so beetle/splitty or early bay if you add extended to rear over gearbox tin. TP head tins (pr), under engine tins (2), pre heat pipe tins (2), front air deflector tins (sit exhaust side under head tins) pr, rear tin and one behind pulley, over gearbox tin, Fan, and fan plate, oil breather, fuel pipe. Doghouse over gearbox tin. All genuine VW £65
ELECTRICS
Will update Monday 16 March
BODY / LIGHTS
T2 Earlybay/splitty wide ridge over engine load floor cut (the bit behind the rear seat over the engine/fuel tank) £50
T2 bay delux front windscreen seal new £10
T25 front lights pr £10
TOOLS/Ammo boxes
Snap on long nose pliers, good condition £15
Air regulator / water trap for compressor £5
T1/2/3 clutch alignment tool (bugpack) £3
Motivair 50L wheel mounted compressor, belt driver, excellent condition 240v, new pressure guage and filter trap £125
Ammo boxes, I used to use these to store/transport tools before getting better storage, Ex MOD, VGC £15>25 (choice for 4)
Clarke SB30 Shotblast cabinet with replacement screen and disposable screen covers. Internal grill added so it doesn’t clog and light changed to floor lamp £185 (cost £335 to buy and there is £40 of screens included)
Halfords Industrial 6 Drawer Ball Bearing Tool Cabinet, black, good condition, drawers are lined £125 (currently on sale for £225 so a fair saving)
PORSCHE 944
REAR END MECHANICAL
INTERIOR PARTS
EXHAUST / TINWARE
ELECTRICS
BODY / LIGHTS
TOOLS/Ammo boxes
