My first camper
DjHarman
Active member
Aug 23, 2008
28
Swindon
Back in May i bought a 1970 panel van doormobile conversion. I got it off ebay, didnt look to bad, but when i took it home and stripped it down it was a different story. :shock: Im currently replacing the Chassis parts - the majority of it needs replacing. I can then move onto the body panels. Every time i do more work on it i feel more down at how big this project is.
Here are some early photos
Here are some more from the next day where i started stripping the van:
I dont have any more photos from the last 2 months, so ill get some sorted. But basically i have taken the floor off and cried over the chassis :cry: , all outriggers etc need replacing. Most of the main rails need replacing too. At least when the chassis is out the way i can move onto the more fun stuff?
How much does a typical restoration cost? im only 19 so money can be tight sometimes, so im just wondering!
Couldn't say exactly how much you'll end up spending but can say that it will be worth every penny and then some. Stick with it my friend and that day will come !! I've owned lots of great cars but none better than my 68.
Chin up mate,most of us have been there/are still there. Will give you something to do in your spare time.I think everyone who has so much work ahead including myself gets a bit dis-hartend every now n then. Just walk away for a few days or weeks and come back to it with a fresh head :) Dont give up and youl have a real cool bus that you built to show for it. sure any info you need youl find on here someware :mrgreen: Rich
Deffo what Rich says, when shes finnished & on the road she,ll look after you on your travels..
Stick with her & good luck
Andy
Looks like you have your work cut out there, check out haveacampers thread in the gallery as he is restoring a dormobile in slightly better condition than yours.
if you PM him he might even tell you how much he has spent so far :wink:
Is yours originally a dormobile? I ask because it looks like the roof pops up the wrong way round for a RHD. Is there fittings for a cooker behind the passenger seat?
Im pretty sure it was converted (poorly) at a later date as the hole in the roof isnt really cut neatly. Would the pop top be able to go on the other way easily?
As for the cooker, there wernt any fixings when i got it. There is a big hole for what looks like a pull out magazine rack!
Why do you ask about the cooker?
hi DJ welcome to EB, with a project of this size i would definitely teach myself to weld, get a clarke or such welder and think of every repair as a separate item and dont look at the van as a whole, it wont look so daunting.
Cheers! im already learning loads from looking through the forum! Luckily my dad is a panel beater, so he is showing me to weld and how to do all the different repairs. So hopefully i can crack on with it all! Thank you for all the comments :D
Quick update. Took some photos of the chassis etc so you can see the damage. Im waiting for an engineer to make half of each rail to make replacement a bit easier so i cant really do much with the outriggers and jacking points at the moment.
So ive ended up stripping more of the van down to see what else is hiding. Here are some photos
Engine is now removed, Bay isnt Tooooooo bad!
Ive cleaned and primered the fire guard
My dads project
Im working on the small holes around the van, and might start cleaning the engine bay up until the chassis parts are ready
ill keep you updated
Respect. :shock: That's one major project.
:shock: :shock: :shock:
Looks like knowing how to weld would save a bucket load :wink:
good luck mate!
Looks like alot of work. Fair play to you, keeping another EB alive.
Wish I had the time and skill to be able to do this..
wow. thats a lot of rust.
if i were you mate i would ring one of the many parts importers like mj, volks heaven, volks magic, fbi etc and get some cuts of us vans. and simply chop off the bad bits. you can buy complete fronts, rears, corners arches etc. you could get it solid again
my van had the same sort of chassis rot and i replaced most of it with schofields repair lengths. and then improvised on the bits you cant buy.
