1971 BAY WESTFALIA
roybird
Jan 9, 2019
14
8
Hi
I'm new to Forums but have posted ( or thought I had ) a request for information on the water tank in my Westfalia.
If the moderator can confirm this is the right route to take, and also where I check for a reply it would be VERY much appreciated!
As I've had no response
Regards
Roy
You posed questions on here
http://forum.earlybay.com/viewtopic.php?p=612215#p612215
And they were answered in the ongoing discussion. :)
But...
Once primed, the tap should hold water, I’d suspect the seals aren’t correct or seated properly if it’s not holding the fluid.
I’m not sure he thread size on the tank but there’s only one sort so if you look for another original part it will fit . Refit it using some curing sealant.
The hole in the floor is larger than the pipe to allow movement, from factory they had a piece of ribbed black rubber/plastic to seal the gap but allow movement.
