Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
What the hell is that whining noise?!!
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ozziedog" data-source="post: 602572" data-attributes="member: 13810"><p>Is there any sign of wear? Like where something’s been rubbing where it didn’t ought to be rubbing? The noise,, whatever it might be, is more than likely components rubbing and not a high frequency or a harmonics type thing. If it ain’t right ,and it’s the only thing that you’ve found, just double check the box end and the hub end and make sure they’re rotating nicely while you got this little monkey out.</p><p></p><p>Ozziedog,,,,,,,, I hope you’ve cracked it :mrgreen:</p></blockquote><p></p>
[QUOTE="ozziedog, post: 602572, member: 13810"] Is there any sign of wear? Like where something’s been rubbing where it didn’t ought to be rubbing? The noise,, whatever it might be, is more than likely components rubbing and not a high frequency or a harmonics type thing. If it ain’t right ,and it’s the only thing that you’ve found, just double check the box end and the hub end and make sure they’re rotating nicely while you got this little monkey out. Ozziedog,,,,,,,, I hope you’ve cracked it :mrgreen: [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
