Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
sticky indicator
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="mginty" data-source="post: 607329" data-attributes="member: 4155"><p>I have a similar problem in that the indicator will stick on & not flash. </p><p>Problem is the relay and been trying to get hold of the old style (new style requires some modification) </p><p>Solution at moment is if I pull hazards lights and close immediately it seems to reset the relay and indicators flash again <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p></blockquote><p></p>
[QUOTE="mginty, post: 607329, member: 4155"] I have a similar problem in that the indicator will stick on & not flash. Problem is the relay and been trying to get hold of the old style (new style requires some modification) Solution at moment is if I pull hazards lights and close immediately it seems to reset the relay and indicators flash again :) [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
sticky indicator
