Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Near Side Rear Brake Drum Binding - advice please
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="cpt scarlett" data-source="post: 503163" data-attributes="member: 13385"><p>Thanks for the advise guys, I will change the hoses tonight and see if that resolves the issue</p><p></p><p>pillpopper I ordered all the parts from GSF online, if you use CC20 discount code you get 20% off</p><p></p><p>rear drums - 600VG0020</p><p>rear shoes - 631VG0070</p><p>fitting kit (springs and bits) - 625VG0140</p><p>rear cylinders - 654VG0150</p><p></p><p>no need to replace the backplates unless they are really corroded</p><p></p><p>cheers</p></blockquote><p></p>
[QUOTE="cpt scarlett, post: 503163, member: 13385"] Thanks for the advise guys, I will change the hoses tonight and see if that resolves the issue pillpopper I ordered all the parts from GSF online, if you use CC20 discount code you get 20% off rear drums - 600VG0020 rear shoes - 631VG0070 fitting kit (springs and bits) - 625VG0140 rear cylinders - 654VG0150 no need to replace the backplates unless they are really corroded cheers [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
