Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Inverter to run electric 1kw or 2kw fan heater
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Happystamps" data-source="post: 604028" data-attributes="member: 14679"><p>As per Bullet Tooth's response, I'm afraid. you can use a 1kw fan heater with an electric hookup on a campsite, but trying to run it off a leisure battery is a mug's game. For when you're off-grid, you've got the following options:</p><p></p><p>-Light hobs. Effectively free, might die of CO poisoning/fire.</p><p>-Camping Gas heater. £30/thereabouts, same downsides as the above.</p><p>-Propex- Runs off gas, perfectly safe if fitted, serviced and used properly, 2kW output and reasonable battery life. About £200 second hand or what- £500 new? Take a look on VWH.</p><p>-Eberspacher- Runs off petrol/diesel, same details as the propex, you'll likely be looking at about 2kw output but you can get bigger ones. Same cost roughly second hand, more new (£800 or so?)</p><p>-Alcohol- Fairly cheap, fun at first, can become an issue in prolonged winters. Need to wee a lot.</p></blockquote><p></p>
[QUOTE="Happystamps, post: 604028, member: 14679"] As per Bullet Tooth's response, I'm afraid. you can use a 1kw fan heater with an electric hookup on a campsite, but trying to run it off a leisure battery is a mug's game. For when you're off-grid, you've got the following options: -Light hobs. Effectively free, might die of CO poisoning/fire. -Camping Gas heater. £30/thereabouts, same downsides as the above. -Propex- Runs off gas, perfectly safe if fitted, serviced and used properly, 2kW output and reasonable battery life. About £200 second hand or what- £500 new? Take a look on VWH. -Eberspacher- Runs off petrol/diesel, same details as the propex, you'll likely be looking at about 2kw output but you can get bigger ones. Same cost roughly second hand, more new (£800 or so?) -Alcohol- Fairly cheap, fun at first, can become an issue in prolonged winters. Need to wee a lot. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
