Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Indicator switch wiring help
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="dublicious" data-source="post: 605844" data-attributes="member: 15752"><p>Ok indicator in and working <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /> the other dodgy switch is for hi and low beam as dimmer relay is missing and wires go straight into the fuse box :/ </p><p></p><p>Dimmer relays hard to source?</p></blockquote><p></p>
[QUOTE="dublicious, post: 605844, member: 15752"] Ok indicator in and working :) the other dodgy switch is for hi and low beam as dimmer relay is missing and wires go straight into the fuse box :/ Dimmer relays hard to source? [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
