Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Deluxe side trim - LHD or RHD?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="kinga" data-source="post: 605417" data-attributes="member: 7595"><p>That's exactly what I thought Walt - surely if the profile of the trim is the same top & bottom, if you turned it over & used it on the other side, it would still be the same - apart from the rear quarters, as I believe they will be either kinked upwards of downwards, although again, surely these wouldn;t matter if it was a LHD or a RHD bus?</p></blockquote><p></p>
[QUOTE="kinga, post: 605417, member: 7595"] That's exactly what I thought Walt - surely if the profile of the trim is the same top & bottom, if you turned it over & used it on the other side, it would still be the same - apart from the rear quarters, as I believe they will be either kinked upwards of downwards, although again, surely these wouldn;t matter if it was a LHD or a RHD bus? [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
