Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Compression Ratio
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="gagvanman" data-source="post: 629146" data-attributes="member: 17411"><p>Here are the current specs:</p><p>New Aluminium Autolinea case</p><p>Stroke 69mm</p><p>Bore 90.5</p><p>Cylinder Head - CB performance 044 40 x 35.5mm 90.5</p><p>Solid Rocker Shafts</p><p>Standard 1:1 rockers</p><p>Camshaft Scat C35</p><p>Valve train geometry set with 60" rocker shims and shortened pushrods</p><p>Compression Ratio 7.5:1 set with 1mm barrel shims</p><p>SVDA Distributor</p><p>Twin Weber 34 ICT carbs.</p></blockquote><p></p>
[QUOTE="gagvanman, post: 629146, member: 17411"] Here are the current specs: New Aluminium Autolinea case Stroke 69mm Bore 90.5 Cylinder Head - CB performance 044 40 x 35.5mm 90.5 Solid Rocker Shafts Standard 1:1 rockers Camshaft Scat C35 Valve train geometry set with 60" rocker shims and shortened pushrods Compression Ratio 7.5:1 set with 1mm barrel shims SVDA Distributor Twin Weber 34 ICT carbs. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
Compression Ratio
