Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Technical
Anyone know what these clips are called?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="cunning plan" data-source="post: 606694" data-attributes="member: 4090"><p>Thanks for the explanation Abel. <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite7" alt=":p" title="Stick out tongue :p" loading="lazy" data-shortname=":p" />arty0047: </p><p></p><p>The one in the picture above is not the one I have, it is just a picture I found online for reference. The one I have is the 'flat bar' version, which as you say, is the single port one then! :? </p><p></p><p>As long as it fits, I do not mind adjusting the holes to suit. :character0036: </p><p></p><p>Thanks for the heads-up, I will have a good play with the flaps to ensure the spring is working as it should. I'll also mark the bar so I know when it is open.</p></blockquote><p></p>
[QUOTE="cunning plan, post: 606694, member: 4090"] Thanks for the explanation Abel. :party0047: The one in the picture above is not the one I have, it is just a picture I found online for reference. The one I have is the 'flat bar' version, which as you say, is the single port one then! :? As long as it fits, I do not mind adjusting the holes to suit. :character0036: Thanks for the heads-up, I will have a good play with the flaps to ensure the spring is working as it should. I'll also mark the bar so I know when it is open. [/QUOTE]
Verification
Post reply
EarlyBay Forums
Technical
