Forums
New posts
Search forums
What's new
New posts
Latest activity
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
EarlyBay Forums
Camping
240v generator or solar? Or other?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="aogrady" data-source="post: 509159" data-attributes="member: 3512"><p>Hi,</p><p></p><p>I have a 80W solar panel n my westy rear roof section, adjustable for height depending on the sun, with a digital solar MPPT regulator, with a T Max winch recovery digital split charge system, 25mm thick cables to minimise voltage drop, along with a 80aH sealed AGM battery, but i have a 210aH Trojan ultra deep cycle, pair of 6V cart batteries to fit, but will relocate the starter battery and fit a Red Top or similar under the bed.</p><p>I am also running a efficient marine Waeco CR50 12 compressor fridge in the OG westy coolbox</p><p></p><p>When i get around to it anyway, the solar set up etc is all documented, with links etc in my build thread, take a mooch</p><p></p><p>Cheers,</p><p></p><p>Alistair</p></blockquote><p></p>
[QUOTE="aogrady, post: 509159, member: 3512"] Hi, I have a 80W solar panel n my westy rear roof section, adjustable for height depending on the sun, with a digital solar MPPT regulator, with a T Max winch recovery digital split charge system, 25mm thick cables to minimise voltage drop, along with a 80aH sealed AGM battery, but i have a 210aH Trojan ultra deep cycle, pair of 6V cart batteries to fit, but will relocate the starter battery and fit a Red Top or similar under the bed. I am also running a efficient marine Waeco CR50 12 compressor fridge in the OG westy coolbox When i get around to it anyway, the solar set up etc is all documented, with links etc in my build thread, take a mooch Cheers, Alistair [/QUOTE]
Verification
Post reply
EarlyBay Forums
Camping
